- Joined
- 17 Aug 2004
- Messages
- 30
- Reaction score
- 0
- Country
HI,
We have a single storey apex roofed extension which is used as a childs bedroom. The extension was built using lightweight thermalite blocks and it has cavity wall insulation (the foam type). The floor is a suspended chipboard floor. The loft space above, is insulated to 200mm. Three of the walls are external walls.
When the heating is not on the room is cold, and not long after the heating has been switched off it goes cold again. It has a one double radiator in it, which is slightly over the BTU required for this size of room. There are three air bricks to keep the air circulating under the suspended floor. I have tried covering up the air bricks to see if that helps, but it doesn't.
Any ideas why it could be getting cold ?
Many Thanks
Many Thanks
