Starting my extension I dug an inspection pit along my garage wall which I will be building alongside. Trench was 900mm deep, with 450mm of concrete. It had a tough black plastic sheet running down the side of it, around 15mm thick. Building inspector seems to think the foundations are probably piled. Suggested an earth test to see if the ground is suitable for strip foundation, how much? Where can I find someone?
Other than finding an actual pile, any other tell tale signs of foundation? Any site I can find the plans on the
Build, site is only 12 years old. Taylor Wimpey. They were unhelpful.
Will piling cost loads of required?
