Hello, my wife and I are in the process of having an extension built on our semi-detached house. The work is fairly advanced but we’ve got some issues and the builders are not communicating very well with us (or Building Control). It is a timber frame with outer brick skin, tiled sloped roof, and the back wall has been opened into the new structure. The architect drew up plans in brick and block, and never updated them to reflect the change to timber frame but he did mention using 140mm timbers. The builders have erected the frame made using 2x4” with 2x6” for roof rafters. The roof is 15 degree pitch, tiled with two velux windows. The structure is watertight at present, building control are happy with the foundations & structural side (including steel to make opening to house which was designed by a structural engineer).
Building control advised the builders to check with manufacturers for U values. Builders have used rock wool in the walls and wingspan in ceiling and insisted that they’d done this plenty of times before and it’s never been an issue w/BC. They weren’t bothered about contacting manufacturers so I did (only had an response from wall insulation ppl) and they advised that the current wall insulation won’t get near the 0.18 required u value (that’s R value of 5.56). I asked them what I would need to do to get there and they said to add 65mm thick insulated plasterboard which is not feasible.
As I said the builders don’t seem to be communicating very well. The boiler (combi), which needs to be moved, was switched off over the weekend as the flue opening is inside the house so we have no hot water (no electric showers either).
I’m really frustrated and very stressed out as the builders (and I) really want to crack on with the work, but I feel BC won’t sign it off if we can’t show proof that it will achieve U values. Any advice would be greatly appreciated.
