Many thanks for quick answer.Can you please also through some light on bonding question a bit further.I have put this question on forum before but did not get decent answer but the usuall abuse.Earth bonding arrangements in my house are as follows,Lectrician said:There is no specific requiremement to supplymentary bond any items in a kitchen......If you had a shower or bath in the kitchen, that would be a different matter
Mains rising water pipe from street to where it enters the property is plastic.copper pipe starts after main isolation stopcock in the property.Did you mean that i connect main bonding cable to copper pipe after main isolation stopcock.megawatt said:The copper pipework of the incoming water rising main should be bonded as close as possible to the pipe after it enters the property which is generall immediately after the main isolation stopcock (don't connect the bonding to the plastic )
10mm cable generally okay.
Though often hard to achieveShould be accessbile.
Lectrician said:Within 600mm, and before any tees.
Thank you for decent answer.yai46 said:yes that is correct... as soon as it becomes copper
Thank you for good advise.Lectrician said:Within 600mm, and before any tees.
