I have been trying to find the source of water (small puddles) which appeared under my kitchen sink. No sign of leaks and when I ran the taps and watched the pipes, nothing. Then I suddenly had a bright idea - I tipped a bowl of soapy water down and one of the pipe joints (plastic) erupted into a foamy mess. I have tightened the joint and put tape on the thread but the problem persists. I know some of the wags on the forum will say don't use washing up liquid again, but is there actually a solution to this problem? It's where the pipe from the smaller sink connects to the main run; it's a hand-tight screw joint. I wonder what you think about wrapping some waterproof tape around the top. The washer is fine, by the way.
