Hi all
I'm having problems with my HSA6400 alarm. Everything worked fine when installed 4 months ago, but now the siren will not learn in to the control panel. I've tried all of the help and suggestions found in other posts and followed the correct procedure from the Yale site. It doesn't seem to matter what procedure I try the siren will never beep to say it has received the signal from the control panel, even when sitting next to it.
To cut a long story short I purchased a replacement siren and still can't get it to work even after a factory reset and complete re installation.
Could it be the control panel failing to transmit and if so can anyone recommend where I can get a new panel without paying for the whole kit.
