Hi all, I'd like some advice on the following please
1) I'm adding some additonal joists in my old house mated (side bv side) to the existing 4.3 metre 9*1.5 inch joists
The new joists are 9 by 2 as while the ceilings were down I noticed the existing had dropped slightly possibly caused by the notching or general age hence I wanted to add in some additonal supports.
I am putting the new joists in fully supported on both ends (onto an intermediate wall and into the other house wall) so running the same span as the original joists.
I would like to attach and bolt to the existing joists but where should I position the bolts over the 4.3 metre span (middle or top or bottom) of the joist. I was going to use M10 coach bolts and have some two inch square large washers that will hopefully spread the load. Is this ok and how many bolts should I use over the span?
2) To support the joists while the bridging wood is removed I have acro'd the joists being worked on and noticed that the drop is less. Should I drill and bolt while the joists is undergoing the acro prop support or let the existing joist relax before bolting?
thanks very much
thanks very much
