I have read on the forum that it is advisable to up the size of the water supply from the cold water tank to the hot cylinder if using a shower pump (this would be a 28mm feed).
My question is: If the pump is to supply all of the hot (with no other tappins for hot from cylinder), would It make any difference being 28mm cold feed opposed to 22mm.
I know that this is advised in case of emptying hot cylinder but thought that as there is only one 22mm pump out, a 22mm feed from the cold storage tank would be ok.
This will be a new instalation (not done yet) so it is not a matter of changing pipe work to one or the other, just a case of getting it right, but not using 28mm unnecessary!
Also the cold connection to the cylinder is 1" male, does this take a special kind of fitting/connection (tank connector) or just a 1" female to whatever with PTFE!
Many many thanks !!!
