We have a ceramic electric hob and are looking to add a two burner gas hob (possibly a wok burner) to our kitchen. I wont be doing this myself but just interested in the reply to be "in the know". If that gas pipe is not feeding any other gas appliance, would a 15mm copper pipe be more than sufficient for an ordinary more recent 4 burner gas hob (no oven) let alone a 2 burner wok style hob that I will be having installed? I see on some forums people are mentioning 22mm pipes but for what I have described, would that 15mm be sufficient? The copper pipe will probably be teed off from a 22mm connection from the garage which will feed a boiler. The total distance of 15mm pipe between boiler and hob will be approx. 9m max and probably around 5 or 6 elbows.
Secondly, is it perfectly acceptable to have this pipe buried under 100mm of Kingspan insulation boards with wet underfloor heating above the boards and then screed and tiles?
