Size of hole for 60/100 flue.
4 Apr 2008
Glasgow
I need to make a hole for a 60/100 flue for an Intergas Rapid 32 boiler which is soon being commissioned.
The flue will be going through a plasterboard, PIR insulation board and cladding.
What is the contentious regarding the diameter of the hole for 60/100 flue going through the above material?
Can I just do a 10 cm hole? Or will it be too tight and need to make one slightly bigger for expansion? i.e. 10.5, 11cm?
Thanks.
Yup +1 for 127mm - always good to have some wiggle room or if the boiler needs fall back on the flue.
If you get really good and a straight flue is ok then 117mm can be used but there's no room for error and wouldn't go any smaller.
