is it possible to remove what i have been told is size that has run down etched windows. we are renovating our edwardian house and the entrance is spoilt.
Size is a bit of a loose term. Take it you've tried Hot Soap and water already. If it's an oil based size you could try linseed oil, If its acrylic Acetone (nail varnish remover) should work.
