Sizing walls
16 Jan 2022
I'm in the process of redecorating my hall - have stripped all the old layers of wallpaper and paint off but not sure if the walls need sized prior to new paper going up - the walls are the old plaster which has been filled in places. It's a 1910 or so tenement.
They have obviously been papered before so it's not a fresh surface, and I watched one video where a guy seemed to do a test by wetting his finger and running it across the wall to see if it left a mark (although he didn't properly explain it) - have done this on mine and it doesn't show.
Reckon I'm ok to crack on and get the paper up? Or best to size them?
If the walls are dry and damp free then pasting the paper should suffice. If the plaster is not smooth consider skimming or using lining paper, as imperfections do show up
I am using lining paper - sorry if wasn't clear but my question was if i would need to use a diluted coat of adhesive to prep the walls before actually getting the paper up.
