hiya,
me again!
Have a couple more questions, the walls which I am about to skim have the original plaster, I have removed all the bad plaster back to brick and will fill with some bonding plaster, the remaining plaster is in good nick and has not come away from the wall (have tapped).
Then.....I am going to:
a) Use some plastering tape (should i use a particular type) to cover the hairline cracks on existing plaster
b) PVA (50:50 mix with water) the wall and leave to dry for a day (to seal)
c) PVA (50:50 mix with water) the wall, leave till tacky then skim
Is there anything I have missed??
Am just a bit concerned that all the hairline cracks will re-appear (although the pvc seal should stop this?), I know you can never avoid a few cracks due to shrinkage and movement, but just do not want to do the above for no reason.
We cannot afford to go back to brick, so if the above is futile we will paper the existing plaster as it is in good nick and will just replace the bits that need doing.
me again!
