Skirting Board and Door Frames Help
19 Feb 2010
Belfast
Hey, I am in the middle of refurbishing my living room and I am getting it replastered next week so in the process of removing skirting board and door frames etc but it is prooving to be very difficult
First the skirting boar isnt very deep and actually goes down the back of the floorboards, I think it is actually in two bits, the actual skirting board and then a bead running in front of it, I am using a crow bar but struggling to get the skirting to break off cleanly and just splits and causes havoc, also the door frames run down the back of the door bases and because of the way I have to remove the door frames I have slightly damaged the door base.
Will it be better to replace the door bases also and how big of a job is this to do?
Here is a rubbish picture showing what I am talking about.
http://img685.imageshack.us/img685/1246/image569.jpg
Thanks for any help or advice.
Confused as to the problem? what are door bases? :?:
You can cut the skirting on the wall to reduce length removed and splitting.
You can also try punching the nails holding the skirting right through the timber to loosen it, or failing that there's always the option of just trashing the skirting and replacing with new.
I assumed he was trashing the skirting, unlikely to be able to re use and most would replace.Don't see how you can knock nails thru they are likely to be cut nails into brickwork which can' be knocked thru.
It is likely the skirting is fixed to wooden plugs in which case it is quite possible to punch through. However, as you say if he is trashing it, it is academic really.
