Hope everyone is well.
I'm looking into putting new skirting in after an LVT flooring install - please see photo.
I'm thinking about DIY'ing it as there are only a few external corners and mainly internal.
Part of the walling is plasterboard which is easier to attach the skirting to. However, parts of it are exposed blockwork which is recessed due to plastering. The original skirting was attached via nails and with bits of plasterboard stuck in the recess to provide the backing for the skirting.
How best to reattach new skirting? The skirt will be slightly taller so it will hide the recess. I was thinking about attaching plasterboard pieces via screws in the block and then screwing into these pieces through the skirting? Little hesitant using expanding foam.
Any advise would be appreciated.
