I have a loft conversion that is boarded out and ready to skim, do I put the skirting boards on over the skim, or skim up to the skirting boards ?
I need to cut holes for the double socket back boxes in the plaster board - at the moment the cable is pulled through a hole at this point, is there a method for cutting the holes in plaster board. I was thinking of using a hand held angle grinder, although the cut wont be that refined in the corners, and would have to be careful around the cable.
