Skirting Height
1 Dec 2019
Is there a recommended skirting height to ceiling height general rule of thumb?
We have 9.5ft high ceilings and so need a decent size board to make the finish look right. Me and my partner have different ideas of what the correct height would be.
What would you recommend.
Matter of taste, doesn't really do anything apart from hide gaps, but with ceilings that size I'd agree with Notch, ie a good size one.
moulded high skirtings, no matter the material, typically come expensive per metre.
for a cheaper option: you can rip smooth faced ply or similar to about the height needed, and then, after pre-painting, plant a bit of moulding on top.
I need to look into the prices but assuming cost is not the main driver what material would you recommend. I know MDF is used in almost all new builds and i have used myself previously. Is there any issues with using MDF? I assume it will be the most cost effective pre molded option.
Id go 200mm / 8"
Anything smaller would look a bit puny
I would use 6-8” skirting , though it’s personal choice , homes with 8 ft ceilings have a variety of sizes , have seen 2 1/2” up
Yes , I used 165mm pre primed mdf , 4.2m lengths from Selco .
MDF is not only the cheapest, it's also available in long lengths (we see it up to 6 metres - so less joints) and it paints out far better than softwood does (no knots, etc)
There are some massive skirtings in houses -I made some for a builder last year 370mm high
If you can, use mdf -wide skirting in pine will cup.
