Hi all, i had 5 or 6 large bubbles appear under the eggshell finish on some skirting, after opening these up I found knots under (presume the never had knotting solution on them before paint).
Anyhow I've chipped the paint away over and around these knots,wiped them down with white spirit to remove the sap, sanded them down and the surrounding area and applied knotting solution.
My problem is once I fill these (polyfilla) and rub down when I damp wipe down to remove the dust all the filler rubs out , done this twice now and its happened both times
What can I do?, should I prime the filler after sanding, then lightly rub down and then damp wipe
PLEASE Help me this is really holding me up and I cant get all my painting done with all this dust flying about
