Sky/ Satellite Extension Lead???
9 Mar 2006
Kent
Hi, I am looking to extend my Sky lead....
It comes into one corner of my front room and I have just moved TV to opposite corner. I have taken skirting out so can run a lead behind, and would like to run upto flush mounted wall sockets.
A) Whats best cabling?
B) Do I need to have a phone line with my Sky?
C) Will anything interfere with the picture?
D) Do joins in cables greatly effect picture?
All this with HD coming in through Sky very soon
Any Help greatly appreciated
Confused Monkey
The cable you must extend with should exactly match the existing cable.If the installation has been done by reputible rigger it will be satellite coax cable identified usually by a black outer plastic casing and the outer earth sleeve is usually solid thin copper screening as opposed to braided.
Your phone line from the digi box does not need to be connected to recieve your satellite channels but will stop you from fully utilising some interactive services (ordering box office movies etc)
Generally extending your cable a few more yards will not cause interferenc to your picture but the join should correctley jointed.
To join two cables probably the most simplest way would be to fit coax plugs to each cable leaving two male plugs and then and then join with a double female coax interconnector sockets. these are small inexpensive components.
If you wanted to extend your terrestial uhf cable this could be done in the same way and terminated at the tv end with a double coax flush outlet plate one for the uhf output for terrestial and the other "f"socket for your sat decoder.
