Hi, this is my first post and I admit, I have not read the rules yet, so please go easy on me.
I am not a qualified electrician but come from a science background so I know the basics quite well. Recently, I replaced an old PIR Bulk Head with a new PIR Bulk Head. While replacing the light, I found out that the old one had 3 terminals SL, N, and L where as the new one has only got N, Earth and L.
Moving on, I noticed that yellow wire being used for SL in the old light. Traced it back to the wall switch and figured there were 3 Red wires connected to the L in the wall switch and Yellow wire (it had a red sleeve over it) connected to L1. After carefully examining and using a line tester, I figured I cant hook up Yellow wire to the earth terminal on the new light as turning the switch on will supply the current to the internal metal cover.
To me it seems like the stupidest thing ever to use Yellow wires for switching. The house was built between 1999-2001 and have the original wiring. Anyhow, I figured out the correct connections through the wall switch and placed the 2 Red Wires to L and the one (Red) going to the light to L1. Now, the light works well with PIR functioning as expected with ability to override it etc.
I then checked hallway and landing area switches (the ones with double switching) and they are also using Yellow wires for switching. Checked a few other wall switches without double switch and they have the usual Black/Blue and Red/Brown combination.
a.) Is this standard practice to use Yellow wires for double switches?
b.) What is SL? It's easy to understand N (Neutral), L (Live, Line or Hot Line) and Earth being Earth. Does SL stands for Secondary Live?
c.) Are there any good electrical books which covers the fundamentals, historical standards and current regulations?
