Hi, I have a composite door fitted. The door is dark blue and bows when hit by the sun. The bow is within manufactures tolerance as far as I can tell. The door is fitted with a slam shut door mechanism with ‘trigger’ top and bottom latches. Currently the top and bottom keeps allow for the door bow. Should the keeps be adjusted to stop the door bowing or will this stop the latches triggering when the door gets hot? Probably over thinking it but sometimes the door is tight to open.
