Slate cement repair prior to Kingspan installation
24 Oct 2004
House aged about 1920, slate roof, externally the roof is in good condition. Part of the loft has previously been converted to a bedroom. prior to my purchasing the house. An extension off the loft has no insulation between the rafters. I intend to use Kingspan K7 100mm, I informed Kingspan of the type of roof and the fact that there is no sarking, they said this would not be a problem. My only problem is that much of the plaster/cement on the underside of the tiles has either fallen off or is about to fall off. I would like to replace/repair it before I fit the Kingspan can anyone tell me what mix I should use. Should I put PVA on before I apply the mix
maldin
