I am proposing a 4 metre deep extension on the rear of my house, I want the floor to be suspended timber, so I will have to build sleeper walls, but how many?
Lets say C16 47x125 regulised to 120 at 400 centres will span up to 2500.
47x100 at 400 centres will only span 1.87 Your choice.
Would be cheaper and easier to build in and fit C16 47x200 regulised to 195 and no sleeper walls.
Don't forget about your insulation
Regards oldun
Yes. If you put a central sleeper wall in, it is difficult to get joists perfectly level. The floor will also feel 'light'. The deeper joists will make for a heavier and probably more rigid floor (that's assuming you've got adequate clearance underneath for ventilation). Remember to incorporate central strutting.
Thanks lads, I will have a problem with clearance beneath the joists due to existing ground level outside, so 4x2's with a sleeper wall will reduce the problem
