Sleepers on concrete
7 Feb 2008
I've got some mini sleepers; 1200 long, 150 wide. I want to run a line of them (just one high) along my concrete drive as an edging.
Can I lay a bed of ballast, say 15mm deep (using 10mm stones) and just sit the timber sleeper on top of it?
Many thanks.
why do you need to lay them on anything? i guess your drive is flat? and the sleepers big and heavy enough not to move anywhere?
a lean mix meaning very little cement. just enough to hold it together.
If the drive is quite flat and you only need a bed 20mm deep 6 sharp sand to 1 cement would do.
If you need to have deeper beds 20mm+ then put some 10mm stone in at say 4stone 3 sand 1 cement
They could just sit on the concrete drive surely? :eek:
1200 mini sleepers are quite light. The drive is narrow and used frequently, they will keep shifting so I would rather fix them.
oh, if you need to stop them moving laterally you would need to haunch them with concrete like a kerb or drill holes and put pins through them, re-inforcing bar works well for this.
or if you didn't want to drill holes, maybe lay them on carpet underlay? might stop them shifting?
