A
angelf
Can copper pipework be sleeved through a wall using pipe insulation or does it have to be copper ?
but can the pipe insulation be used as a method a sleeving a copper pipe through a wall?
transam";p=" said:As a matter of interest , & if I remember correctly ??? u are able to get plastic coated 10 mm copper , some use to come with what was refered to as having interslice's formed in the plastic coating , this was or is ???? deemed to be suffiecent as a sleeve , for nat gas ???
are you refering to kuterlex,yellow coat for gas, white
coat for oil.
It's been removed that the sleeve has to be the same material
as the pipe so you could use an abs,iron,etc sleeve
