slide compound mitre saw
30 Aug 2010
London
I short-listed two mitre saws. I am looking for an accurate and good enough (for a perfectionist DIYer) slide compound mitre saw and I was wondering whether any of you could say which one of these is better. Or are there other ones that you's recommed instead?
1. HITACHI C8FSE 216MM SLIDE COMPOUND MITRE SAW MAKITA LS0714 190MM SLIDE COMPOUND MITRE SAW http://www.toucantools.co.uk/hitach...mpound_mitre_saw.html?search_string=mitre+saw
2. MAKITA LS0714 190MM SLIDE COMPOUND MITRE SAW http://www.toucantools.co.uk/makita...mpound_mitre_saw.html?search_string=mitre+saw
I occasionally do high end commercial fitted bathrooms, loads at a time normally, but i also use it at my properties any where from roofing to simple skirting, i went for this
http://www.toolstation.com/shop/Power+Tools/Saws/SIP+12+Dual+Bevel+Mitre+Saw+230V/d40/sd2966/p33485
and the stand
http://www.toolstation.com/shop/Power+Tools/Rollers+Stands/SIP+Mitre+Saw+Stand/d40/sd3162/p57387
The equivalent Makita or Dewalt is around £700 i believe, which is a price worth paying if you are using the machine every day but i think this machine is absolute quality, all the usual brands at around the £300 price range didn't feel as sturdy and well made as this.
Try a local toolshop and get a hands on.
Here is a vid of it
https://www.youtube.com/watch?v=XQaTTFsrX0w
Ive got the Hitachi, its a nice machine. TooledUp had it on offer a while back.
I dont know about prices but i do know that mitre saws are all about pretty specific uses.
Obviously, anyone doing framing or cut roofing or wide trim work would want a 10" or a 12" - but they are heavy.
For shop work or cabinet work then the smaller ones are just fine.
Most seem to swap the c/w blade for a good quality 60 or 80 tooth.
Some very cheap saws have blade wobble and loose setting at every cut.
Well said ree a 12" saw is not for diy I have used the hitachi and its a good saw plus its light.
