Sorry if this is worded a bit confusingly!
When using my sliding compound mitre saw the clamp attached to the saw base is located on the left hand side of the base.
I'm right handed so use my right hand to control the saw - thus it can't hold any wood which is to the right of the blade - any timber here becomes loose after I've cut through the workpiece.
I've tried moving the clamp so it's positioned on the right, and this gets in the way of the saw motor .
So my question is this - do I need to worry about the timber being supported/clamped/held on both sides of the blade or is one side OK? If the offcut is quite small is this OK unclamped or could it cause a problem?
Hope this makes sense, thanks
