Hello, would be grateful for some advice.
We're replacing an existing PVC window with sliding aluminium doors 2400mm wide. The depth of the aperture is 300mm comprising two 100mm brick skins and a 100mm cavity and the installers will be removing several courses to get it to floor level.
The depth of the window frame from front to back is 115mm, and the installers are allowing a 45mm rebate from the external elevation, which presumably means that the unit will be sitting on 55mm of brick and 60mm of cavity. Does that sound right? How would they fix something that heavy without filling the cavity first? Thanks.
