- Joined
- 5 Apr 2004
- Messages
- 121
- Reaction score
- 6
- Country
I cannot tell you the model number as there is no label inside the fridge where it should be .But that should not really matter .
What im after looks a bit like what would be used on plastic curtain rail .
Basically we have an intergrated fridge/freezer and the doors on the fridge/freezer are not the same size as the kitchen unit it is inside .
So to get around this what has been fitted is what looks like a strip of plastic about an inch deep 6 inches long on the inside of the units door .On the front EDGE of the fridge door is a plastic bracket that has slightly folded over edges that the strip inside the unit door goes inside .
So basically when you pull the units door it opens and slides down the strip .
I will personally kiss someones as* if they can tell where to get one from ,like i say it shouldnt matter on the model as this could fix to any fridge like this .
I have tried partmaster and MFI i know they have this item but they need a part code and i have found on sites SLIDING HINGE KIT but i cant see an image so dare not order it for it being wrong .If only i could see this parts image and buy it somewhere it would help
Alan
Alan
