Slight leak from capillary air vent
13 Dec 2011
Hi, I was just wondering if anyone would be able to help. In the airing cupboard there is a section of pipe that tee's off from a pipe that links the diverter valve and hot water tank. On top of this pipe there is a capillary air vent.
The cap on this has started to leak very slightly down the sides rather than from the tiny hole. I was just wondering if changing the cap would stop the leak? I assume the seal has gone? Its done it before but sorted it self out, I assume the limescale sealed it.
It sounds like B&Q have decided to 'metricate' 1/2" BSP, and sent one of their goons out with a vernier caliper to do it! :evil:
I suppose 1/2" is near enough 12.7mm, even if 1/2"BSP actually has a major diameter of 20.955mm
Is that 12.7mm the same size as some of their other 1/2"BSP fittings listed as 19mm (the minor diameter of 1/2"BSP)?
Now I know why there's a blanking plug opposite the bleed valve on a rad - you remove that and use a long rad. key to open the valve..... :LOL:
