I have fitted some new taps and a new waste to my existing bathroom sink.
Taps are fine, but i have a slight leak from underneath the basin.
It appears to be coming from between the underside of the basin where the rubber washer and plastic nut tighten onto the porcelain.
I did have a concern as the hole underneath in the porcelain did not appear to be consistent all the way around so i applied more of a liberal amount of sealant than would typically be necessary.
Looking more closely at it now, the shape of the porcelain has caused the rubber washer to bulge out a little so i think this is the cause.
I looked for a 1.5" equivalent of a shaped trap washer (see this link http://www.diy.com/departments/plumbsure-trap-washer-pack-of-3/178382_BQ.prd ) but could only find a 1.25" so just used the standard flat rubber washer that came with the waste.
I was mindful not to over-tighten the plastic nut by the way.
I am resigned to the fact that i will have to dismantle and redo but wanted to see if anyone can offer any advice as to how to prevent this happening the next time please ?
FYI, this was the order from top to bottom :
Waste
Foam washer
Bead of sealant
Top of basin
Underside of basin
Sealant
Rubber washer
Plastic nut
Many thanks in advance
Waste
Foam washer
Bead of sealant
Top of basin
Underside of basin
Sealant
Rubber washer
Plastic nut
