Hello all
1st visit in here , I’m looking for some advice :-
Unoccupied 2 Bedroom Semi , no central Heating at present
The Property is undergoing a full refurb , with a recently added single storey Extension , this is where a problem has arisen :-
Whilst drying out I’ve noted that in one Corner of the Extension there is shadowing almost a damp type stain with a slight growth on the face of the Plaster , this growth wipes off no problem , there is a small similar area of staining under the Steel Lintel area and at the bottom of the Doir reveals , The Wall is Plasterboard dot & dabbed then skimmed , Walls are Brick / Rockwool Wall Slab / Blockwork
The Extension was built during inclement Weather but was covered up as best as it could be during Construction , there is no new ingress of Water on checking Walls etc
putting a damp Meter on it shows around 20% on the majority of the Walls but around 26-28% in the problem area
I’m questioning will this staining / growth go away as the Walls dry out further , when painted is it likely to break through the Paint finish
is there a primer I can paint the Walls with prior to decoration ?
Any feedback would be appreciated
thanks
Phil
thanks
Phil
