I have found a very slight sweat coming from a soldered joint in my bathroom. I can see that the solder hasn't filled around the joint completely anyway which explains the leak.
It's not spraying or dripping out, it's just you can feel moisture underneath it which reappears after wiping it away. Anyway I would normally just take it out and resolder the joint but it is in a very unaccessible location.
Is there an epoxy resin or putty I can use to stop the leak? There is no pressure there it's just sweating out.
