Hi everyone,
I've spotted cracks in several rooms within my house. Property was built in 1995 and is a detached home. Cracks are visible in the plaster only and do not run through to the external brickwork. The cracks have appeared below the bedroom window, below the landing window and around the Lounge window.
Here is the crack below the landing window. It runs from the window sill to the skirting. Directly below the crack is the properties front door? I filled this crack approximately 9 months ago when we decorated and it has since returned. -
This is the crack in the bedroom, again it runs from window sill to skirting board and again has a sliding patio door below? As above, i filled this about 12 months ago whilst decorating and it has since returned -
Finally, these are the lounge cracks. Initially a thought the ceiling cracks were just poorly taped plasterboard joins but now cracks have appeared on the walls around im not so sure. The cracks on the walls are either side of the windows. -
Does anyone have any ideas on the cause and solution to these cracks? I'm don't think its subsidence as the cracks do not run through to the external brickwork but then im now surveyor either.
Many Thanks,
Russ
Many Thanks,
Russ
