My split load consumer unit is wired as follows:
Non RCD:100A Isolator
Upstairs lights 6A MCB
Downstairs lights 6 A MCB
Outside lights 6 A MCB
Alarm - 6A MCB
Garage (attached) - 16A MCB radial with a RCD FCU feeding 13A sockets
(Garage is used as a work shop and has 9 double and 2 single 13A sockets to save trailing leads but other than low power chargers etc there is only ever one socket in use for power tools at any one time)
RCD Protected: 63A RCD
Final Ring 32A MCB
Boiler + 2 13A sockets 16A RCD Radial (Boiler in upstairs airing cupboard and sockets in loft for aerial amp + spare)
Oven 40A MCB
Shed 16A MCB Radial - Shed has its own local consumer unit feeding a light and a two 13A sockets - one with built in RCD.
This all works OK but as I may be having some notifiable work done in the kitchen in the future there is an oportunity to change things.
Any independant advice/ comments on the above set up would be appreciated.
Alarm - 6A MCB
Final Ring 32A MCB
Oven 40A MCB
