sloping extension concrete floor
27 Jul 2009
Cheshire
As a newbie, I am looking for advice on screeding my kitchen floor. Have searched the archive but still have a few questions.
The property is a 1930's semi with kitchen extension added on to the rear. The extension floor is a concrete slab with DPC and is dry. There is an archway through what was the external cavity.
The original builder got the slab height wrong and when they broke through there was a 2" height difference with the internal suspended wood floor. In true bodger style they flaired out the hight difference over a few feet so there is a nice ramp into the rest of the house.
I now want to run laminate flooring through both rooms and need to get both floors at the same height.
First question is how do I cope with screeding from 2 inches at the far end of the room tapering down to zero at the threshold to the wood floor? I know that the new slab can not be less than 15-20mm otherwise it will crack so should I batten off the 'ramp' area, cast up to it, let it cure and then use a leveling compound to flatten out the ramp?
The alternaive I suppose is to chip out the ramp and create a step to accomodate the new screed.
Minor problem, there is a fully fitted kitchen on the slab at the moment, any tricks to avoid having to strip out all the units?
All comments gratefully received
