I set of B&Q taps earlier in the year as part of a bathroom refurb earlier in the year but a problem with the basin draining slowly due to the pop up waste not popping up very far.
Remove the pop up waste plug and the basin drains very quickly and freely. But the throw on the lever that raises and lowers the waste isn't sufficient to raise the plug far enough that there is much of a drainage path.
I can't get any more throw on the lever because it runs in a slot at the back of the tap. I've tried adjusting the plug position itself but to get it to drain well the plug then doesn't seat and if the plug seats then it doesn't raise far enough to get good drainage.
I've run out of ideas. Any suggestions would be much appreciated!
