Hi.
The problem is that the water from the kitchen waste runs away very slowly.
There is the usual S bend and also a washing machine is plumbed into the waste pipe, The waste pipe (32mm) then passes through the wall and then along the outside wall for approx 10 feet before joining into the main down pipe to the drain. The fall of the waste pipe outside seems sufficient.
Is the problem caused by the sheer length of the waste pipe? Would fitting a hopper help?
Any suggestions gratefully received. Dud.
