Our bath drains through a 40mm pipe into a hopper and then down the drainpipe and into the drain on the drive. It has some bricks around the drain to prevent leaves blocking it.
The problem i have is the speed of the water flow when it empties is too fast for the drain on the drive and so the water spills over and floods the drive every time we have a bath.
Is there a push fit device i can fit onto the end of the 40mm pipe which goes into the hopper and will act as a brake on the water flow ?
