I had to extend a pipe on a radiator at the weekend to clear an extractor duct, which required draining the heating system. We've had a new kitchen fitted and the drain valve was behind one of the new units, but i had the guy cut an access hole so no issues there... set to with some pliers trying to open the valve. It was siezed solid.
Got a larger holesaw and made the access hole larger so i could get a bigger spanner in, still siezed solid. Gave up, drained the radiator into a bucket by undoing fittings at the rad and got the pipe sorted.
This morning i figured i should order a new valve, so when i replace the radiator in the room we're currently refurbishing, i can swap the valve out for a non siezed one.
After some searching i finally found online, a picture of the valve thats currently fitted:
https://www.mkmbs.co.uk/prodl009875-compression-15mm-bronze-sludge-cock/
Its something called a "sludge cock". And when i found the picture, i realised it has a nut on the back of it. A nut thats currently inaccessible thru the hole i've cut in the back of the kitchen unit. So perhaps, the valve isnt siezed at all and this nut is the key...
So i'm now wondering, does that nut "lock" the valve, and thus the reason i couldnt open it is because it needs slackened first? Also, what on earth is that valve supposed to be for and whys it used on the drain for my heating system!
Cheers
Kev
Cheers
Kev
