I had problems with having no hot water and a plumber came and said there was an airlock. He put a tubing from the cold water tap to the hot water tap and used the pressure to unblock it. The hot water started to flow freely. The property has been left empty for 3 weeks and the problem has arisen again. This time the plumber has said there is debris in the hot water cylinder and a new cylinder is recommended which is very expensive.
is there any way that this gunge in the hot water cylinder can be removed. The cylinder seems to be in fairly good order and replacing it seems to be an easy option for the plumber
