sludged exchanger
18 Sep 2008
Cardiff
hi .a sludged heat exchanger. would the boiler make kettle noise and what would be the expected temps of flow and return pipes in such a scarnio? just trying to discover how i can recognise this problem on site. thank you chaps and merry xmas
A scaled up h/exchanger will kettle and give you some heat then go cold as the overheat stat kicks in as the limescale cooks the h/exchanger.
You mainly get the sludge depositing in the rads and pipework
Pete
invariably, you will find cold spots in lowest rads; compare the middle along the bottom of the rad with the sides near the valves. if the middle is colder, you have sludge.
