We are considering replacing our existing boiler after. We have come to the conclusion that the present position is the most suitable for us and our engineer is suggesting a Valliant boiler as it has a stainless steel heat exchanger and we are in a hard water area. The only problem is that it is much larger than our present one and will block a good amount of worktop space (in a small kitchen).
Can anyone recommend a smaller combination boiler which is reasonably reliable? The present one is height640mm, d280mm, width440mm. We would be willing to add a combination of another 800mm to the height/depth.
