Small closer for internal door
22 Nov 2018
What's a good closer for internal doors? Not the big ones which go on the top of the door.
The question should be "What's the easiest closer to remove after you've banged your head or walked into the door edge?"
Otherwise, rising butt hinges.
If you can't incorporate rising hinges, look at Perko fasteners - but watch your fingers when you install them! (also requires its' own thread)
Probably requires plasters and bandages as well.
