Been thinking more and more on this idea and have drawn up a floor plan here:
http://www.floorplanner.com/projects/20189135-new-floorplan
Couple of questions though:
1) How deep would the foundations need to be, it will be a single story less than 4m high.
2) I was planning on building the walls using 9 inch block double skin with a cavity in the middle and then having the external rendered, does that sound ok?
9 inch concrete blocks external and 9 inch celcon blocks internal?
3) The largest wall which is 6.5m could only be partially rendered as the neighbours lean to would obstruct access the render the entire wall, would that change what blocks I would need to use?
4) There will be a man hole cover under the wc I think (one of the 2 small rooms) which I would build a removable panel into the floor or is there another way?
5) Is there a way to calculate how many blocks I would need?
Thanks for the help in advance, currently the area is decked, under that is a small layer of tarmac and approx 75mm of concrete under that covering the whole area, I was intending to dig the foundations down approx 600mm or is that to shallow?
