Because my room is not completely square, I have had to cut a long triangular shaped bit of plywood to fit in between 2 large sheets of plywood on the floor.
I could not get an exact fit so there is a 10mm gap at one end of the ply.
I think the tile will be supported by the ply anyway but is this okay or should I fill up the gap with adhesive? That part would then have adhesive on the floorboards...
