Old electric shower removed. In hallway there is a hole in corner of ceiling where the mains cable ran into loft. When I removed it the area aroound was just filled with caulk i think and some paper in a ball. Wasn't great finish.
I also have another hole in the bathroom from where the pipe and mains ran down to old shower unit.
Was thinking of just using a bit of expanding foam and filling with patching plaster ? Will this work? Or would you recommend anything else?
Local merchant has Jetcem Quick Set Patching Plaster
- http://www.everbuild.co.uk/index.php?route=product/product&product_id=696 - which I was going to use for other repair jobs and smoothing out walls and cracks etc in the hallway and thinking of using this onto an expanding foam such as this - http://www.everbuild.co.uk/index.php?route=product/product&product_id=50.
Only thing with the patching plaster it says "Only use on porous surfaces. Do not apply over plastics, sealants, paints or primers." Does that mean it will not work on the foam stuff? Foam can says you can plaster over the foam stuff. Bit confused.
