Small kitchen corner wall unit
23 Apr 2007
I'd posted this
//www.diynot.com/forums/viewtopic.php?p=1324803#1324803
in the appliances forum but I wonder if a thread here but come up with an answer.
I'd like to fit an extractor hood over a corner hob and under a corner wall unit. A telescopic hood would fit under a corner unit without projecting out to far but all the corner wall units I've found are about 72cm tall which will not give me the necessary clearance of 70cm required above a gas hob.
Are 60cm, or even 40cm, high corner wall units available?
Cheers
Andy
You could cut down a standard unit and buy matching door size, but you would need the door first in order to obtain exact measurements for cut down unit [bridge unit draw fronts are around the size you need]
Foxhole,
Thanks, I've been thinking along those lines as well, as it seems that small corner units do not seem to be available anywhere.
cheers
Andy
