Upstairs i have a leak on the radiator from where the pipe goes into the valve.
I have turned off the valves.
what i want to know is will i get a lot of water coming out when i pull out the pipe to push it back home a bit better ?
Do i close all the other upstairs rads off as well so no water comes out from here and pushes down to my open joint ?
ant tips on minimising water ? would i use some ptfe tape on the end of the pipe going into the valve ?
