HI
I'd like to put in a lintel either 1.2M or 1.5M (maximimum) into a single inner skin of blockwork covering the fireplace and making up the wall. I'm thinking that since its only a small opening, that a concrete lintel 65mm high would be ok?
I've got two props and strongboys but I'm trying to understand once the course of blocks is propped up, should I remove the entire row of blocks below and installed the lintel should I then perhaps infill with bricks above? Or should I try to carve the block to about the height of the lintel with the props in place? (And could I do this ok with an ads chisel hammer or must I use a large grinder which I'm afraid would make a real mess of dust?).
Thanks in advance for any advice on this.
